how much power will i get?
SEBASTO
........... how much power (on each SUB) will i get.. when i wire two KICKER comp15(250rms @4ohm SVC-each) in parallel (2ohm load) ...with this AMP 1 x 325 WRMS @ 4 Ohm (14,4 V, 1% THD)
1 x 550 WRMS @ 2 Ohm (14,4 V, 1% THD)
1 x 650 WRMS @ 2 Ohm (14,4 V, 10% THD)
700 watt maximum output power
2 ohm stable
yeah....//content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif
That depends on the volume level but basically take 650 and divide by 2. That's a high average of what you might get from the amp. You may see more if you allow more distortion or you may see less depending on the volume level and gain setting.
SEBASTO
SEBASTO
somewhere in Europe
GMCJimmyslt2000
