How much louder would this be?
Dual 4's wired paralled to 2 ohm
//content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gif that one is wrong already bro. should be a 1ohm load if its parallel. also there are better amps than that MRP1000. switching the amps will give you more output. i would get something a little bigger with more headroom to play with if it was me
I think the guy on CL said a 2ohm cause each sub is wired to 2 ohms. If they were both wired together at 1 ohms his amp would go into protect, especially if it's bridged.
Do you have each sub wired to a channel on the amp?
Nope thier both running off 1 channel.
stay_high
stay_high
Florida
stay_high
