How much are amps overrated by
for instance; im lookin at this power acoustik amp and its tellin me 125X4. what variables do i need to look at
Depends on what you spend for the amp
Like a sundown amp in MOST cases is underrated (not sure of any where it isnt but I know someone on CA would prove me wrong)
on the other hand a new sony xplode amp from walmart has astronomical ratings.
Couple days late...
Good indicator for cheaper amps are the fuses on em.
So if you find an amp that claims 1000w+ and has a single 30A fuse on it, be realistic.
For reference at 12v:
10A = 120w(beyond max)
20A = 240w etc...
If your looking for true 1000w, aim for 100A+ worth of fuses on it. 100A is 1200w, and thats beyond what should be coming out of it. Keep in mind thats still low, but you'll get the idea.
Couple days late...Good indicator for cheaper amps are the fuses on em.
20A = 240w etc...
You also need to account for efficiency, a class d is around 80% so that 100A fuse x 12 volts x .8= about 960 watts
a class AB is about 40-55% so 100A x 12v x .5= about 600watts
what about a Power acoustic a3000db underrated or overrated sonic says it puts out 1800wrms at 2ohms just wondering what it realy puts out at 2 ohms thire is no exteranal fuses so the fuse method dont work
Not sure how accurate this statement is:
Planet Audio VX2200d. Same amp internally as the Power Acoustik A3000db, Planet Audio TT2250d, Kole Q1-3000d and O2 Audio OAD3000.1
from http://forum.ecoustics.com/bbs/messages/4/425146.html
Fender5
Fender5
Arkansas
94Mazda626
