You can wall 2 10's. and a blow through is a trip to a tool rental place and $75 for the accordian boot.I don't have the tools or the money to do a blowthrough. A wall for 2 10's seems silly though...
I actually think a wall would be easier. So if i especially since i'll sell the truck later. So if i made a "wall" i would just wall off the whole extended cab part. Then make the actual box behind the wall screwed/glued on?(because 2 10's i was figuring about 3.5^3)You can wall 2 10's. and a blow through is a trip to a tool rental place and $75 for the accordian boot.
Build your enclosure, then build a front baffle to help seal it off. You can use xpanding foam as a seal around the baffle.I actually think a wall would be easier. So if i especially since i'll sell the truck later. So if i made a "wall" i would just wall off the whole extended cab part. Then make the actual box behind the wall screwed/glued on?(because 2 10's i was figuring about 3.5^3)
i think you will be much happier with this set up, in cost and in performanceyou want 6k with a 200amp alt? You might need a lot more SPL dust for that. You might want to go with a dual alt setup. 2 200 amp alts
im all for overkill but this is just bullshit.you want 6k with a 200amp alt? You might need a lot more SPL dust for that. You might want to go with a dual alt setup. 2 200 amp alts
Agreed, I have 6 deep cycles in my truck on a stock alt and I dont drop below 13 volts. I dont drive around at full tilt either.im all for overkill but this is just bullshit.
people (like me) do this all the time with a stock alt
i have 2 20.1's which put out who knows what kind of power on 1.4 ohms strapped.
it holds at 12.2 just fine during my runs.
is it 13.8 or 14.4, no but its working just fine for me.
Truck off, battery rack is at 12.8v. 14.1v when running. I charge them before a competition or after beating on the system for a while. I could get by without charging them they seem to bounce back pretty well.i need to put my batts on a charger
what does your car sit at when off?
