How important are quality RCA cables?
Promodmerc
I recently had my system jacked (HU, AMPS and sub) and was fortunate enough that insurance covered everthing. They even replaced all the wiring for the amps. Instead of issuiung me a check they actually shipped all new replacements. The wiring kit for the amps they sent are the bottom of the barrel stuff you see on ebay and the RCA cables are as cheap as you can get.
The amp is a Kicker DX400.4 (4 chanel x 50w RMS) I will not be replacing the sub at this time. Can I get away with the low quality RCA cables or do I need to invest in some better quality ones? I don't want to do this twice.
The amp is a Kicker DX400.4 (4 chanel x 50w RMS) I will not be replacing the sub at this time. Can I get away with the low quality RCA cables or do I need to invest in some better quality ones? I don't want to do this twice.]/B]
you just answered your own question
quality RCAs are relative to the install. everything is really dependent on the quality of the install and the quality of the connections. i've seen ppl with $100 RCAs make noise and I've seen $2 RCAs sound crystal. I seen an install by a guy who ran power and cheap RCAs on the same side with no noise, and similar install with "quality" RCAs whine like a hungry baby.
Promodmerc
Promodmerc
Raytown MO
Promodmerc
