How hard is it to take out rear seats in an 01 Ranger?
Its alot easier said than done. I went out there and got all of the regular bolts out. But then I got to the ones that hold in the seat belts. Which have a star shaped pattern to it. I dont have a screwedriver or anything of the sort.
That's a torx head bolt. go to your local hardware store and ask for a T-55. Or maybe it's a T-50 I don't remember but I'm almost positive its the 55. I'd get one for a 3/8 ratchet because they're put on tight and you need a lot of leverage to get em off. And don't try and use an allen key cuz it will just strip it right out and then your FAWKED
^x2
i beleive it was a 55 as well in my truck ('00 B3000, same as an '00 Ranger 3.0l)
also, do you already have the jack removed? if not that will be a PITA. i store my jack under the drivers seat now //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
and you will need a good 1ft or more rachet to break thoes torx bolts loose, they are the hardest ones. Had to of been torqued to 100 lb/ft from the factory.
WHen I took mine out I ran into the same problem with the funny screws I just used some plyers and worked it out very slowly it took a while but i got it done.
It seems like that bolt for the seatbelt is T40. I ran into the same problem and broke two big T40 heads trying to get just one of the seatbelt bolts off. I gave up after that //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
Update!
I finally got those stupid seats out. And I have moved the box back. It made a big difference on leg room.
This is before I took them out.
And this is after
What do yall think?
supraman1379
Lifted 03 HEMI
supraman1379
Ocala, Fl
supraman1379
