How does this build look?
Shinkster
Amp - Rockford Fosgate 1000 Watt Mono B/D
Sub - x2 Alpine SWR-1243D 12" Type-R
(i'd provide links but I don't think new users can, I'm getting an error)
This would be going into a 2004 Mazda 6. Price isn't too important but I'd rather not spend more than 700. I was told this amp wouldn't provide enough power unless I wire it in parallel twice...which confuses me. If this amp isn't a good match can someone point me in the right direction?
Thanks!
I could spend 800 total and still afford to eat if that's what you mean //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Above that just seems excessive, especially for a first build.
If Im interpreting the model number correctly, your subs are dual voice coil 4ohm. If you wire them in parallel twice, the total load will be 1 ohm. Check the specs to see if its stable at a 1 ohm (mono) load.
Don't forget you need wires and stuff.
What kind of bass are you looking for, homeslice?
Heavy bass to go into a ported box, almost enough to shake the enamel from my teeth //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
There are many better subs out there than Type R's for that price. Remember: the enclosure is the most important thing in a sub stage.
I'm not dead set on the Type R's or anything, I've just heard good things...I'd love some other recommendations though.
whats your max box dimensions... WxHxD
H 16"-17", W 40", D 42"
Shinkster
Shinkster
Boston
nauc
