how do you do interchangeable ports?
crfrider
a yes how would I go about doing a interchangeable port, i want to do like 32-35 hz for everyday, then do a like 40-45hz for spl? how would i go about doing a interchangeable port? I was wanting to do a slot port so how can i do that, which tune would be a bigger port, then would i just slide in a smaller port into the slot? any help would be great thanks
well the slot would be more of a rectangle port...just make the cutout larger to accomodate the port, slide it in and bolt it down....say your spl or higher tuned port is 4wx10tall" 5" long and your daily low end port is 4x10" 12"long. make a rectangle that's 8x14...to leave a little overhang so you can bolt to the box...and cutout a hole centered that's 4x10. then make your port walls...example is 5" long, take into account of the .75 from the top plate and each piece would be 4.25 long....then the same for the low end port.....then since this one is 4x10 you would cut a hole in the box that is 4.75x10.75 to slide in the port( assuming you are using 3/4 wood)...then screw it to the box.....make sense????
square port i made out of birch attached that was 8x8, i made one for daily and one for comps.
thanks guys for the help i think i under stand so the length of the port makes the different tunes? yea twoeggcustoms take some pics if you dont mind well im not failiar with areo ports it seems that it would be easier to change but i dont want ports sticking out
youll have to ignore the extra sheet of wood i got there one of my 10s is out of commission so i grabbed the first peice of mdf i had and covered it up... then the duct tape is for decoration //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif had a little water leak lol
not guna take it out right now unless you really have to see it... but the bolts you see come out and the port slides out i have my 50hz port at the other house the one in there right now is 35hz box is double baffled you can see where the baffle ends and the port begins...
btw if he is still running around here i didnt make this box so ill give credit where its due.... Cannon White built it and it is one of the best boxes ive used...//content.invisioncic.com/y282845/emoticons/toast.gif.bc0657bf54b9ee653b6438524461341e.gif
figured i might as well show the rest of it too //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
box is 6.5 cubes with 2 3/4" steel braces and fiberglass resin on the inside made for 3 10s for a truck but i got a good deal on the subs and the box came with so... previous owner is a good friend of mine
crfrider
crfrider
Oklahoma
rosshimself13
NorthFramingham
    Jun 30, 2026
