How do you connect a 7 band eq to the farenheit 8.3 touchscreen deck
How do you connect a 7 band eq to the farenheit 8.3 touchscreen deck threw the decks already speaker pre amp speaker wire set up? Nitro/ p tek 7 band with 3 pre set to the farenheit 8.3 motorized touchscreen. Or should I forget the eq and flow threw the deck, (my amp pushes 2000 watts).
speaker and pre amp are 2 diff.things...are you going to use speakers leads or rcas to run this?
if rcas,run the front,or rear,from the radio,to the input of the eq and run your other rcas to the eq.
Does the amp push 2000 real watts or 2000 lightning strike watts //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif How much power do your woofers put out ? What brand amp is it ? That might help knowing the answer to some of these questions on what would be your best options
wmblocke
wmblocke
inland empire, ca
Louisiana_CRX
