How do you clamp an amp?
to do it properly, you need a dmm, and a clamping ammeter... plug your dmm leads into your speaker terms, set it to ac, and clamp your speaker wire as close to the amp as possible, then play your test tone (closest to your box tuning) ... then take the two readings and multiply them... and bam... rms wattage
copied this from a '02 thread
How to test an amplifiers output
saw this on another forum and thought it could come in use....
Now there are a few things to remember during these tests. One is your resistance will not be your nominal ohm load. In other words if you have a 4-ohm sub, the amplifier will not be seeing 4-ohm when being tested. Another is input voltage will have an effect on the amplifiers output. So be sure to check the input voltage to make sure it is consistent during multiple tests.
There are a few items you will need: True RMS clamp meter, DMM, pencil, and paper. These items are needed for a simple test.
Having a friend available will make this much easier.
Test 1:
Hook the DMM to the + and - speaker wires coming out of the amplifier. Set the DMM to AC Volts. Do not use the peak hold function as this will give you an inaccurate reading.
Place the clamp meter around the + speaker wire coming out of the amplifier. Set the clamp meter on AC Amps. Once again do not use the peak hold function.
Now simply play your frequency. You will need to play it for roughly 2 seconds to give the meters time to "settle". Simply write down the numbers you get for AC Amps and AC Voltage. Then you can use Ohm's Law to figure out your ohm load when playing and your amplifiers output at that given time. Or you can simply plug your numbers in http://ourworld.compuserve.com/homep...en/ohmslaw.htm to figure everything out for you.
There are other tools needed if you want to maximize your amplifiers output. One would be an oscilloscope. Just an example is different amplifiers like different waves. MTX amplifiers tend to like a clipped wave to put out max power where RF amps tend to like clean waves. This is something you would have to test with your paticular amplifier to see what it likes and to get the most out of it.
The_Grimy_One
The_Grimy_One
Phoenix, AZ
kmanian
