how do u wire an amp to a stock HU?
  • 4
i am assuming that there are no rca outs on the HU. if your amp has a high-level input you can connect it via the speaker wires by splicing the rear left and right channels and sharing the signal with the amp high-level input. if you dont have the high-level inputs on your amp then you will need a "line-out converter" in which case there will be more detailed instructions with the converter. as for the remote wire, if you HU does not have a remote out or a power antenna lead (which may turn off with the radio anyway... meaning no amp for listening to cd's) just connect to the fuse box to a fuse that is controlled by the ignition (i.e., radio, accessories, etc.)
yo maylar... i hate that too... if i had known he posted more than once i probably would'nt have answered. i usually think to myself, "what an impatient ****" and then skip to the next thread. lol
Originally posted by maylar You really didn't have to ask the same question in 3 forums.
maylar, my sincere apologies, my friend was very anxious to connect his amp to his H/U very early in the morning (2:30 if i remember) and we were in dire need for an answer. i usually though amp gurus stuck to their forum so on and so forth. my recent behavior mightve been from the excessive consumption of paint chips and an acetone replenisher, once again, my sincere apology. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
yeah, it'll be hot but off. Just like your tv when it's plugged in.
If you have multiple amps you do not need to run a power wire from each amp to battery.. You can have a single run of wire with a distribution...
EMR sniffer or AM/FM sniffer. small radio but with a probe antenna to it. It gives you the specific location on the ground loops. This device...
26
I agree…not a very good install. Hopefully you didn’t pay much (hopefully it was free). Get your DMM (or find someone who has one) and find a...
b16_na
b16_na
Houston, TX
MikeofTulsa
    May 16, 2024
    May 16, 2024
