how do i?
i have 2 12 oldschool orions.. power accoustik a1000bd mono amp
The amp is turned on but there is no Power going to the subs.. Its powering up and its not in protection..
What do i have to do to fix it?
You must have wired all four coils in parallel....whcih leads to a .5 ohm load...wire each DVC sub in series then wire each sub in parallel for a 2 ohm load...
You can wire them like this:
or like this:
(You can also wire them to 8 Ohms but why would you?)
Wire them as illustrated to where a 2 Ohm nominal load (bottom option) and if you still have no output from the amp and you're certain the amp is getting an input signal then possibly the amp is no good?
Jordantyler
Jordantyler
arkansas
Prowler573
