How do i wire this?
What amp would be best to wire the 1 12" SWR 1242D to..the MRPM50 or RT1045?
I would use wich ever amp that has the moast clean power. Unfortunitly I am not fermilar with either of thoes two amps. That or I would save up some sqrills to buy an amp with an rms out put that better matches you'r sub;) .
This is what I ordered from Amazon. https://www.amazon.com/gp/product/B07MXMPHKS/?tag=caraudiocom-20...
390
the AVIC was a tad more complicated to wire not to mention stuffing it in a smallish stereo hole. thanks for advice.
873
Drill a hole and use the proper protective split loom and hole grommets to keep the outer speaker jacket from knicks and cuts, give just enough...
993
It mostly comes down to weight. You can have a super lightweight cone, soft suspension and aluminum coil on a sub and you pretty much get a pro...
998
bigdougy05
bigdougy05
Gouverneur, NY
johnecon2001
