How do i wire the sub?
SavageShadow
I have one 12" Rockford Fosgate T1 sub in a 1.25 sealed box and a Audiopipe 1500.1D amp.
The sub is dual 2 ohms or can be ran at 4 ohms. The amp does 600rms at 4 ohms and 950rms at 2ohms.
Do i run the sub at 2ohms or 4ohms to make the sub perform at its max.
specs for amp and sub:
amp - output power (rms): : 600w @ 4 ohms, 950w @ 2 ohms, 1500w @ 1 ohm
sub - 600 watts RMS 1200 watts peak, dual 2ohm sub. model is T1 12D2
Also, what is the difference between capcell and a car audio battery? which is recommended more. I will also be doing the big 3 upgrade.
Thanks
SavageShadow
SavageShadow
Detroit, Mi
SavageShadow
