TheLinkster
Hi
I have in my car 2 front speakers and 2 rear speakers. All are currently connected into a 4 channel amp which is set up correctly. Also, if it means anything at all, my CD Player has its own fused power cable running directly to the battery because it drew more power before I installed the amp.
I want to add a subwoofer with its own amp. Something small, like a 10 inch.
I am vaguely aware of what I have to do, such as either buy a "distribution block" or run a second lot of power and ground cables for the second amp.
However I do have a couple of questions.
1) Where exactly does a distribution block go? How is it connected and how are the wires fed to it?
2) When using two amps, how can both of them wire to the CD Player? I ask this because the amp I currently have is already connected to the "Remote" cable on the CD Player, so how can a second amp be connected to it?
I am very new to car audio and have only just started learning about it and installed my own system over the past 2 weeks.
Anyone with experience with this, help is greatly appreciated.
PS: On an unrelated note, I get slight engine noise from my 4 speakers and the pitch of it increases as the RPM increases, but after reading the forums its probably a bad Amp ground.
