How do i make a perfect 15" circle?
There is some hole making thing for a router. The router clamps onto it, and there is a pin on the end of it. You drill a little hole where you want the dead center of your hole to be, put the device in it. Turn the router on, and move it in a circle.
i wish i had a picture of it..
caraudio shops might have some templates.
And to make your own, you can just use a compass. Make the compass exactly 7.5" from the pen/pencil, to the other tip that holds it in place.
but first, you have to know what size cutout you need for the sub, it may not even be a full 15".
Hope i have been some kind of help, and goodluck
--Greg.
Heh, please don't make a full 15" circle. You'll cry when you try installing the sub.
To make a 13.5" or so circle, take a 13.5" loop of string, anchor one end at the center of your circle with a nail or a pin, then trace out the circle with a pencil anchored on the inside of the string loop. Keep it reasonably taught and you're set.
Originally posted by BassBoomer hey gellis4 what are u gonna use to push that xxx u are waiting for?
right now i only have a 500w RMS PPI. but, i'm leaning towards the RE 35.1 1580w RMS @ 1 ohm. or the BE 1600M1, it's the same amp, but might be cheaper.
Originally posted by ChefJoe Heh, please don't make a full 15" circle. You'll cry when you try installing the sub.
a 13.5 " peice of string would give you a 27" cutout :p
If you do have acces to a router and would like to see one of those "templates" for future use (they do come in handy if you build a lot of enclosures) then go to this site and in the index to the right of the screen pan down towards the bottom to "Basic Enclosure Calculations" Towards the bottom of that tutorial there is a diagram of a router template for various sub sizes.
Just thought I'd throw that in. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
theres a jig for a router out there -- its called a jeger jig, its like 14, 15 bucks. I use a rotozip, but I dont think it will go past 12.5". You can always draw the circle and just jig it out, you would be surprise at how close to perfect you can make it.
I built a jig for my Roto-zip, just take a board, but a hole that will fit the end of the roto-zip, and put a screw exactly half of the distance you need from the center of the roto-zip (if you've got one..or osmething similar) and screw the board loosely to the center of the cut out area. Just fire her up and push around the circle...kinda hard to explain w/out pics
is anybody good enough with computers to send me a 13.5in circle you'll i'd have to use a few sheets of paper and tape them up but that would work. If not I'll have to do something else.
Originally posted by i3abyjay25 is every1 sure its 13.5?
nope, but its a whole hell of a lot easier to make a hole BIGGER than smaller... //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
its probably closer to 14" depending...
Supatravis
Supatravis
Ohio
Wonderbread
