Ronmeister
Banned
I think you either mis-read what I typed, or you don't know what you are talking about.i'm sorry...i just see his subs walking around his car holding up picket signs saying "we're on strike"
Gunz4me is right.
Ron
A subsonic filter is a setting on some amps that won't allow to give the sub more than X amount of power under Y frequency, and you base it off the tuning of the box. Normally 10 hz under the tuning of the box is what you set your subsonic filter at.Sealed, sorry just added specs to my sig as you responded //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Please excuse my newb ?'s but what is the subsonic filter?
I know a lot of subs that can reach 10 hz with out reaching their physical excursion limits.lol...... How about reaching their physical limits with regards to excursion @ 25 Hz?
Now I am going to blow the OP's mind by telling him that it is possible to bottom out the subwoofers WITHOUT clipping the amp![]()
Don't you think it could be useful when running a sub in a large sealed box to maximize SPL at higher frequencies? I mean, if the sub reaches max excursion well before maximum power handling due to 20-25hz content, but you aren't actually hearing that frequency of sound anyway, you could concievably increase SPL @ 30+hz by cuttingEDIT:: About the subsonic filter, it's useless in a sealed enclosure. The whole point is to prevent the sub from basically being in a free-aired environment, which is what happens under the tuning of a box. It begins to put less pressure on the cone, and eventually becomes free-air... and, well, we all know what happens there. (With out pressure the sub reaches peak excursion easily and if played free-aired when it's not supposed to be, it damages the sub.) In a sealed enclosure, the pressure behind the sub is kept at a constant, thus, a subsonic filter is useless.
My first gut instinct tells me that the OP's 12w6v2s will NOT do it in his current setup! Without knowing the size of his enclosure it is impossible to predict, but something tells me that the subs will run out of XMAX before they hit 10 Hz.I know a lot of subs that can reach 10 hz with out reaching their physical excursion limits.
****, You've come a long way bro, I remember when you were asking these questions. Good to see another member actually learn here.I know a lot of subs that can reach 10 hz with out reaching their physical excursion limits.
