how do dual alts work?
I'm about to help a friend with a dual setup. I'm not concerned about installation but I'm unaware of how to connect the 2nd alt to the computer. The truck has a connector that attaches to the one stock alt but how to you get the signal to the regulator on the 2nd alt? Some sort of jumper connection?
I know on mine, I can get a 5th alt in over my PS pump if i just replace it with a unit meant for a van, with a remote reservoir. And then I get a 6th in place of my AC comp, if I needed to.
Don't connect it to the factory system. Get an internally regulated alternator and wire it separate. I had better voltage running isolated electrical systems then running two high output alternators on the same circuit with my vehicle. PCM control is not great for aftermarket electrical upgrades
What vehicle??
1993 Suburban 4wd with 5.7L
I have the same exact suburban. same year same everything. it has a misfire though, need to take it to get fixed. I was originally going to throw my 4 18s in there but I decided to put them in the Tahoe instead. im drunk right now
BassAndBeer
BassAndBeer
California
adulbrich
