CadillacMatt
Disturbing the Peace
Hey guys! After doing much research on this forum and around the web I've decided I'd like to upgrade my low end to 2 15" Fi Qs, but I need some help with the box.
Ok... from the threads I've read 32Hz ported is an excellent sweet spot for this sub, giving both excellent low end properties and volume without sacrificing SQ. I've decided on that. As far as size, Fi recommends a ported enclosure of 2.8cuft-4cuft. My trunk is quite massive, as far as car trunks go, I have 40" depth, 19" height and 48" width to work with. Before I go and pick a box, I have a few questions -
1. What would I gain from choosing either the smaller (2.8) or the larger (4) enclosure, assuming I can fit them?
2. If a sub requires, say for example 3cuft, and I have two of them, must I get a 6cuft enclosure?
3. Two subs in a ported box... divider in between with a port for each sub, or one chamber?
Thanks for any help you can give
