How are my lights dimming, badly?
Psyence
Customized
I have the equipment in my sig... a JL 1000/1 on a 13W7 ported, and I have a powermaster 200AMP alternator, 0 guage big-3.
My lights dim like a MOFO still. My battery guage looks like its bouncin around like its dancing also. I dont have the battery in there yet, but could this be why its still dimming? I'm going to get the battery tomorrow... But I just want to know if I should be expecting this to solve the problem...?
sounds like you got a great setup, could definatly be that your current batt isnt supplying enough reserve power. im fairly certain that will solve the problem.
He shouldn't need a new battery. His current 200 amp alt should be giving him all the juice he needs.
not sure how i missed that part. thought it said he had like a 150a alt..... hmmm in theory a 1000w amp could draw aroun 70 ampers, lets say another 100 max for car, that still leaves 30 ampers left. only other thing i could think of is problem w/ alt, problem w/ wiring, or as stated above bad ground....
Well... I have good grounds everywhere... Amps are grounded at the seat bolts, all cleaned and fitting properly...
Well I guess Ill see what the battery does....
if ur car is not running and ur running your system, of course ur gonna get high voltage drops. but when ur car is on, and u have that 200a alt, you really shouldn't be getting that kind of dimming....
-dante
Yeah, this is running...
I have the gains set properly... Im really lost on why it would be getting bad voltage drops...
Back to the drawing board, lol.
-dante
No, when it is running at the engine speed at which the alternator was rated 200A. If the motor puts out 90A at idle and your're bumping hard at idle, then you have succesfully bought the wrong alternator. An alternator does not always produce 200A of current.
i have a 220 amp alt and a 1000/1 and the 1000/1 draws 180 amps and the average car takes about 40-45 amps to run so there goes your voltage a drop. need more batteries or a huge deap cycle
EDIT: alt is 175 amps at idle
Nooblet is correct that when at idle your maybe getting half the alts amp rating. i ordered mine from Iraggi with a massive idle rating.
that amp does not draw a constant 180 amp //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
at just about full tilt three car audio shops in three diff cities said 175-185 amps //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Psyence
Customized
Psyence
Canada
photocrazy8
