posative or negative
lets try again......If there is NO label (+or-) and the wires are the same size. How do I tell + from -
ok we will post it again
put a 9volt battery to the terminals if the cone moves the cone will either move in or out. out is +
no here it is 3 more times in case you missed it
got it?
just a refresher
now i shall end the post, but not before we answer again
What terminal do I stick the batterie to? What end of the batterie do I use?Do I connect are wire to the speaker?
wow //content.invisioncic.com/y282845/emoticons/moon.gif.9d317aec3339ffe7fde0638df52c628a.gif//content.invisioncic.com/y282845/emoticons/banghead.gif.8606515f668c74f6de0281deb475b6fd.gif
connect the wire to the battery and then the other end of the wire to the terminal if the cones moves inward rather than outward you have it reversed and need to switch wires.
its that simple
slideking
Mister Anderson
slideking
Central FL
tRiGgEr
