hot or not (board pic)
thegreatestpenn
lazy genius
There is only limited info on this board you see. From the looks of it, the amp is quite stout. But if there are some "board specialists" that could give me some extra insight on what this amp may be capable of or an amp that it looks like, help me out. Concept cd-3910 btw
CD-3910
3900 Watt Class-D Mono-Bloc Amplifier
* RMS Power 1000W x 1 @ 4 Ohm
* RMS Power 2000W x 1 @ 2 Ohm
* Peak Power 3900W
* Signal-to-noise ratio: 85 dB
* Frequency Response: 10Hz - 250Hz
* Total harmonic distortion: 0.05%
* Continuously vari
did you look on google?
CD-39103900 Watt Class-D Mono-Bloc Amplifier
* Peak Power 3900W
* Continuously vari
I've seen that, even the Site's info is incomplete //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
site might be a clue to the actual company status , all ive seen is lower quality stuff from concept , i wouldnt own any
site has no 1ohm ratings for any of the monoblocks and I know a few of them to be at least 1ohm stable. with this in mind I'm sure info is missing from this amp's page as well.
try it at one ohm see if it runs if not then its not 1 ohm stable, this amp doesnt have to be 1 ohm stable ya know not all amps are
i really wanna try 1/2 ohm, but will stick to 2ohm until I talk to makeshiftaudio or someone else with more board knowledge than me
thegreatestpenn
lazy genius
thegreatestpenn
columbus
thegreatestpenn
Mike Mccabe
