Hoping
solidcrowd
I gotta write a 8 page essay on subwoofer enclosures and this is all i got for now just started like 20 mins ago:
Subwoofer Enclosures
Instead of buying as many subwoofers as you and cramming them in your trunk, just build a proper enclosure. More isn't always better when it comes to buying speakers, unless you have enough room to build the right enclosure. If you go out and buy three 12 inch subwoofers and throw them in a cheap small box, you've wasted your money. Getting the maximum performance out of your speakers is all install dependent. Speakers need...
There are all different types of enclosures you can build for your subwoofer(s). Some have a simple design and are easy to put together but others can be very complicated to design and build. The three most common types of enclosures are sealed, ported, and bandpass. The easiest box to build would be sealed."
I'm just hoping some1 will write the rest lol which i know wont happen but if some1 can give me some paragraphs to throw in there or add a little more that would be greatly appreciated.
High school I'm assuming?
If you want to write a decent paper, you have to organize and plan it properly, just like building a sub enclosure. Don't just start writing down random shit and try to piece it together; this will not work and your paper will be scattered and non-coherent.
Start out by making an outline of the topics you want to cover and write from there. Do you have a thesis statement that the paper is going to support? It sounds like you could have one in that first paragraph.
If you're going to write an 8 page paper (I'm assuming ~2500 word essay; ~325 words per page with 12 font and double spacing), you need to have more to write about than just ported, sealed, and bandpass. You should add some material about quarter wave theory and infinite baffle.
This sounds like a research paper; are you going to cite your sources?
Here is a sample outline that I would use and modify if I was writing the paper:
-Into with thesis statement
-Space restriction
-Desired output
-Enclosure for application based on above
--Sealed
--Infinite Baffle
--Ported
---Passive radiators
--Bandpass
---Orders of bandpass and reason for the order
--Quarter-wave
-Construction and placement
-Conclusion with restatement of your thesis statement.
Oh, and you could do this in 3 hours or less if you got off of your lazy *** and started typing. I typed a 3000 word research paper and a 1500 word research paper in the same night in 5 hours. I got a 97% on the 1500word and a 90% on the 3000word. These were for College English comp2 and World Religions. I knew very little on both topics and still cranked out decent papers because I had a good plan and outline. Get to work or pay somebody to do it for you.
-Space restriction
-Desired output
--Sealed
--Infinite Baffle
--Ported
--Bandpass
--Quarter-wave
thankz, im deffintely gunna use that outline
solidcrowd
solidcrowd
Buffalo, New York
solidcrowd
