Hooking up two Rockford T-1500bdcps
use the pass through on one amp to the second, and use each amp on its own voice coil.
---------- Post added at 10:22 PM ---------- Previous post was at 10:21 PM ----------
didn't see there are two.....use one for each woofer.
Im not going to learn by having someone else do it. Besides, i like to do things myself
use a distribution block for the power to turn 1/0 into 2 4 gauge ,then ground the amps in the same place ... you could run a remote from one amp to the other also, make sure you set the gains with a dmm then to make sure they have the same power output.
njknittle
njknittle
PA
kramer_212
