Hooking Up Secondary Amp
XxSmashaxX
This has been irritating me for weeks now. I have a Pioneer FH-X700BT and it only comes with 2 RCA outputs, one for the L/R Front and one that is R/SW. I have 2 Y splitters, both are male to 2 female. I am trying to hook up a Class A/B 4 channel amp (Kicker CX300.4). I have tried everything that I can think of and can only get bass to come out of the speaker. The amp has built in crossovers and even when I switch it from hi/lo/off it still doesn't do anything but change the bass frequencies. Every time I look up a how to it never goes into enough detail for me. Might I add that I am already running 2 Sundown SA-12s. Anyone with information, PLEASE help. Buying another headunit is not an option at this point.
How many speakers are running off that 4 channel? That rear out has to run the subs, so the front channel with the Y connector can run the 4 channel. You won't have front/rear fader though.
I'm running 4 speakers. I don't mind the fader loss but I split the fronts and I still had no sound coming from the speaker. I only hooked it up to one speaker just to see how it would sound. So am I missing something here? Does my RCA cable have to be a 4 channel or could I just use 2 2 channel RCA cables?
Try plugging an iPod directly into your 4 channel and see if you get full range. Really sounds like you have the sw/r going into that kicker. You should be running 1 rca set from the front out to a Y that splits the signal into 2 left and 2 right.
Isnt that the same as doing a split from the L/R output and then running 2 sets or RCAs to the amp? I'm still pretty new to this kinda stuff so sorry for my lack of knowledge.
Odd because thats how I had it hooked up at first. Could it be that my remote wire is using the same terminal as my other remote wire? That is the only wire that my 2 amps are sharing. I don't use distribution blocks.
XxSmashaxX
XxSmashaxX
NorCal, CA
fasfocus00
