Hooking up amps int the house
binterpid
VA
What is the best way to get car audio amps to be hooked up in your house permenatly? My amps push 1250 watts and 928 watts. I knwo you can do it thorugh a battery charger, but I have known peole that have blowb amps doing that. Is the best way to do it with a power source, and If so what would be the size of the powere source you reccommend?
Just get a home audio amplifier. A 120VAC to 12VDC power convertor with enough current to support a 1000w amplifier would cost more than an actual home audio 1000w amplifier.
get a car battery and a tricle charger if you're dead set on having that stuff inside.
the 120v to 12v we use at work was 450 bucks, and it powers 4-5 1000w amps, 4 4 channel amps, 35 headunits, and like 10 tv's
so it'll do the job, but that shit was expensive.
binterpid
binterpid
VA
mikescanlon
