hooking up a second car battery
could you please elaborate for me ...so are you saying run wires from original battery pos/neg to new battery?
Run both power and ground wire from the under hood battery to the rear battery. Grounding the back battery is not needed but is good as well, although I dont know what the hell you have for power....
Would you kindly tell us what amp you're running, what size alt, underhood batt stock/upgraded?
well i was just curious on how to do it ... and they way you explained it was they way i though it would be i was just makin sure..... even though i dont think i need it but i have a cheap stock car battery going to two 800w bazooka mono amps..
You def wont need it. Just upgrade your underhood batt. Do the big 3 if not already done. You're done, easy stuff.
ya i knew i didnt need the xtra battery but i got like i said earlier two 800w bazooka amps and i just bought like 2 hours 2 kicker CVR 12's dual 4 ohm , gonna run them in parallel.... to get down to 2 ohm
Villeza you're just plain wrong on recommending he run a ground wire all the way to the back. What would make you think 1/0 copper would have less resistance than a huge steel frame? I know in our blazers the frame has less resistance than a few 20 foot runs of copper. Geez... where did you even hear that?
Lol really, make a thread about it, let everyone flame you, then come back to me and tell me you're sorry...noob.
now does the big three really make a good big difference
OMG, I'm about to give up on helping newbies....
Yes, doing the big 3 make a big difference...HENCE the" BIG" in "Big 3". There is also a big 5 but that's only for big system like mine and above.
hansk
hansk
ATL
audiolife
