hooking up 4 led tubes to a switch
titanle
I bought 4-12" neon blue LED tubes and a toggle on/off switch. The switch has 3 prongs on the back: 1 says not used, the 2nd says 12v source, and the 3rd says 12v output trigger. How would I hook this up so the led's turn on/off with the switch. Right now all the tubes have the cigarette adapter connector at the end.
When I was running LED's in an enclosure I pulled apart the cigarette lighter adapters and wired them right to the switch. I got the power from a relay I had wired and ran the ground from the LED's to the same spot the relay was grounded at. Make sure you use the correct size fuses too.
i was reading the wiring diagram and it says connect the + to a hot source and the - to ground once you seperate and splice the wires. Is there not a grounding point on one of the three prongs on the switch? im kinda confused here....
Ok heres what you do
Dont use the one that says not used, easy enough right.
Now run you a hot lead ( one that can stand the current needed ) to each of the led tubes, dont hook it up yet.
ground the tubes as directed ( if it has a black wire ground that easy enough right? )
now hook the hot lead to where you were going to get your power from ( battery fusebox etc ) if they light up YAY good job. Now run you a wire from where you got power to where you plan to mount your switch. Run your wire from you led's to that spot also.
Connect each of those wires to a prong on the switch ( as long as the one that says "not used" isnt one of them and they are on separate prongs your good )
if you need a drawing too **** bad.
lol i finally figured it out....i connect a wire from the + terminal of the battery with an inline fuse holder and attach to the 12v source prong on the switch. Then I take all the + wires from the 4led tubes and attach that to the 12v trigger prong, and take the 4 (-) wires and ground them to the chassis. right? //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
sounds about right to me. All you're doing is completeing the curcuit on your comand....
titanle
titanle
BC, Canada
titanle
