hooking amps to cpu power supply question
Upgrade your main power run to a 2/0 guage wire into a distrubition block. Run a 4/0 guage wire form the distro block to the amp and a 8/0 or 10/0 guage wire from the distroblock to a 6 fused distro block with ground block like this.
Then you will run 16 guage power wires to the 6 fues distro block and fuse each power wire with a 30 amp fuse. Then you will run a 16 guage ground wire for each power supply to the ground block on the 6 fused distro block. After all that run a 8/0 or 10/0 guage ground from the ground block on the 6 fused distro block and ground to the cars frame. If you need a wire diagram PM me.
Plain and simple, no, you cannot combine three power supplies like that. Use one big one. Computer PSUs arnt prime, but you'll be surprised even if you use one of those.
I should have been clearer in my first post. I'm taking some of my olf car subs and amp and hooking it up to my home theatre system. as for cost concern, a 300 rms plate amp runs about a 150 bucks. 3 20 amp computer power supplies are about 60 and can put out 720 max and 310 rms. I thought maybe I could fuse them, put them in a distro block and run them to an amp like a battery bank would run a car's audio system. anyone else have any input?
I know exactly what your saying... trust me, you can't combine power supplies like that it wont do what your thinking it will.. Your best bet is to get a higher end psu that can handle closer to 30 amps and then just keep the gains low. Build the box right and even with 100-200 RMS it will sound good. My 10 amp sh*t psu and a 200 watt max, crap pioneer amp on two crap pioneer subs shook my house... lol
Ya servers might handle a good bit more, nice thinking. For HT, a lot of factory subs are tuned high for performance and space issues. Around 35 is the highest I would personally go. I like to hear everything and give the sub a broad range and tune low, close to 25 Hz and set hpf's to around 100 Hz. 22-100hz is a very nice range for HT application. The best box's iv heard were down firing, about 5 In off the ground with a round port. Aim it in a corner if possible or at a wall and you will be very happy. Depending on the sub, distance will effect it a bit, but generally give it 8+ feet away from the ear for best results. gl man!
Sorry, I meant to say, sealed would be great for SQ, but you can have the same effect with low tuned ported box. You'll get a bit more efficiency and a bit more output that way.
Beatkeeper1
Beatkeeper1
Cranston RI
netzero
