Dozy_production
Poel
I have a 95 civic DX sedan. I was wondering where all you guys put your xoverS? and how did you do the wiring?
Makes it sound a bit easier than it is. Usually the x-overs can go in the doors, however when I stuck my type-x's in there they ended up falling apart. I'd recommend just running two wires into the door and mounting the x-over somewhere in the car.Xover can go in the door, or any location for that matter. Wires ran through the wire grommet in the door.
you shouldn't get much noise running all the wires next to each other, although it won't hurt running them seperately. When I had a low-power component amp, I had some noise, which decreased noticeabally when I re-ran the RCA's on the right side... but with my high powered amp there is no noise at all.thanks. It seems like it would just be safer doing it in the trunk. If you can get static by having your power wire next to your rcas can you get any distortion from having rcas, remote and speaker wires all next to each other? planning on installing the power through the right side of the car (where the battery is) and all the rest of the wire on the driver side.
