holes overlap
taintedplay
ok, i didnt even think of this when i planned my cuts. basically, the subs are 14inch hole i cut for it to fit in. i put an inch between the holes not even thinking. well theres the lip aroudn the sub, so the two lips overlap. so the holes are about an inch to close. what should i do?
Dont use a rubber gasket on one of the subs. Its not going to look very professional but will have no effect to the sound.
Or if you care about looks then go to HD get a piece of MDF and cut a new holes with extra inch space in between
****. i tried taking the rubber gasket off but that cut almost no size off. ill try to turn this peice into the baffle ontop, and use what would have been the baffel as the bottom
taintedplay
taintedplay
dallas
302yota
