Astyl
Car Audio Enthusiast
ive got a 200 Amp EA Alt and it does that 12 volt thing at idle too, and it came from EA with a 10% overdrve pulley and it still does it
My excessive amperage is the exact same way actually, and many other people have this same issue depending on the make/model of the car and alternator. I guess it depends on who makes the alt as well.this is not normal. there is no time in which an alt should be at 12v at idle, unless the manufacturer designed it that way (i dont know of any that do).
this is usually based on the components used. my buddy bought a motor city reman alt with this problem. go too 1k rpm and it was 14.1v. drop to idle and it was 12.2v. they replaced it, for a brand new one, and the same thing happened. smaller pulley helped A LITTLE bit (gained .5v or so). they said his car is to blame, and thats the smallest pulley they had.
we switched it out for a mean green 200A alty, no problems ever. and on my explorer i can take my mean green down to about 200rpms before i see any drop in voltage.
i would call ohio and let them know. that is not how an alt is suppose to work.
I agree Iraggi makes a few of those as well, no charge at idle. I know a smaller pulley helps at idle though with most of his alternators.I dont think you guys are hearing what I am saying about "actual" output at idle... if the alt does low amperage at idle then the vehicles stock electrical needs may exhaust what the alt can supply at idle... this would cause the voltage to drop to 12 or below depending on the state of the battery. I agree, an alt should not do this unless specifically designed that way (like our SPL alt) Hence the reason I suggests our 200A units that do 125-140A at idle //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
If you don't know what a crank pulley is???????//content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gifsorry but i dont know what a crank pully is :x and i idle at 600-800, its never at one place.
