Hmmm... 2 runs of cca 1/0 or 1 run of pure copper 1/0
Well I figure that with a battery bank of 7 XS Power 3100's in the back and 2 XS 2400's up front and running 4 300 amp alts, I never see a voltage drop under 14.3ish at full tilt so why add more. I dunno maybe I could use another run, would it increase my voltage at the back bank, possibly could. How I look at it is the back battery bank is what the 6 SAZ-3500 are pulling off of and the 2 2400's up front and the 4 alts are used just to recharge the batterys, so at full tilt I have only around 1 volt drop from 15.2 idle to 14.3.
So you are pulling about 550 amps through 300 amp 1/0?
nice nice. that works then
Im not sure your exact set up but all of my current pulling amps are sitting right next to my batterys. And each amp might pull 350 max.
mgcauctions09
mgcauctions09
alabama
mgcauctions09
