Hmmm... 2 runs of cca 1/0 or 1 run of pure copper 1/0
mgcauctions09
Ok heres the deal. I am about to buy 2 aqx-35001 amps and running them at .5 ohm each. Roughly around 3700 watts for each amp.
What would be better on each amp? 2 runs of copper coated aluminum new shok 1/0 or 1 run of of kolossus fleks pure copper 1/0? Obviously I can't afford 2 runs of kolossus fleks per amp.
New shock is supposed to be similar to klmx 1/0. klmx is supossedly rated for up to 250 amps. I figure worse case scenario If I run 2 runs that we be capable of 400+ amps.
well in that case maybe u need 3 runs. my wire is rated at 300 amps and 1000 volts so maybe u need some higher rated wire or jsut more runs
Why 3 runs? I doubt the aqx-3500 at .5 will draw over 400 amps. Or will it?
just for reference 200' of new shok will cost $372 shipped. 160' of kolossus fleks will cost around $600 shipped.
you said u were gonna run 2 right? 7k needs about 700 amps of wire to draw that much current efficiently
My bad, I guess you misunderstood me. I will be running 2 runs of power and 2 runs of ground for each amp. A total of 8 runs front to back.
mgcauctions09
mgcauctions09
alabama
mgcauctions09
