High quality non amplified system
eyalriemer
Hello everyone !
i recently bought a 2000 Isuzu Trooper and i wanted to install a good unamplified system consisted of a headunit and 4 speakers.
my experience with amplified systems is that they are tiring to listen to and do not have good midrange sounds (your ears are blasted with treble and bass and after a while you just want to turn everything off) and i wanted a good quality system for a normal price.
i mostly listen to classical music which has alot of midrange sounds that i wasnt able to hear with my last systems.
the front speakers are 6.5" and the rear speakers are 4" and i need a headunit which produce good quality sound and has good tuning options and nothing more (no need for MP3)
Your help will be very much appreciated !
Thank you !!
Hello everyone !i recently bought a 2000 Isuzu Trooper and i wanted to install a good unamplified system consisted of a headunit and 4 speakers.
Thank you !!
There's no reason a system using an amplifier will alter the bass, midbass, or treble. The higher volume created by the amplifier can however make it easier to detect erratic frequency response simply because the louder sound makes the difference in output levels larger.
People tend to notice dips in freq response pretty much instantaneously. While the peaks in freq response tend to be seen as simply the areas where the stereo performs well. But that erratic response, and those peaky output areas, tend to cause exactly what you are describing, ear fatigue. An amplified system tends to be listened to louder as well, only serving to increase the chances of ear fatigue.
technically the head unit has an amplifier, it's just low powered compared to typical aftermarket external amplifiers. audioholic is right about noticing peaks/imperfections with a louder/higher powered front stage.
i feel that midrange sometimes suffers with typical 2 way setups. But this frequently may be caused due to less than optimal install, budget equipment, and/or lack of or poor EQ'ing. If you're staying on budget focus on install variables like axis, nearby surfaces obstructing/reflecting the sound waves, nice seal on the mounting baffle, etc... IF you have semi decent equipment you can make it sound incredible with the right install...
if you REALLLLY want awesome midrange get yourself a 3 way setup. Ever since I went to a 3 way with DLS midranges I've been in heaven. I can never go back to 2 way.
This is what I think too. I don't understand quiet all of it but that's definitely what I think //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Hearing fatigue is also caused by distortion. Listen to something at a mid level volume wise that's either a really compressed recording or somehow distorted. Then crank up something that's really cleanly recorded on a system that will play it with cleanliness. You're going to feel fatigue on the distorted system first, even though it is being played at a lower volume. The high volume will also cause fatigue, but, from experience, you probably won't notice it until the music is done. That's my 2 cents on that one. I say amp your speakers for cleaner sound and make sure the speakers you get suit your listening habits.
An amplified system is going to sound better than running speakers off of your head unit. If you turn your volume up loud on a head unit amplified system, you are going to be pushing the amplifier in the HU much harder than you would with speakers being driven by an external amplifier.
Get an amplifier that will do 100 watts rms x 4. It will sound better than a head unit powering your speakers at 22 watts rms x 4. Much less distortion and this will also leave you room to push the midbass more on your EQ on your HU and allow you to turn down the highs to your preference while achieving the SQ you desire. You are very limited with 22 watts rms per speaker.
Just make sure to get a good quality HU that has a good EQ. Something with a 13 band Equilizer or more.
Sound deaden and seal up your doors to get that mid bass that you are trying to achieve.
Get a 10" sub and an amplifier to get the lows you need. It takes a little more power and cone surface area to fill in your lows in a large cabin such as your SUV. Cars can get by with this easier than SUV's.
Guessing from what you have stated, you aren't wanting a super loud stereo and trying to get that earth shattering bass. Subwoofers arent just meant for bass heads. They add depth to your music that aftermarket speakers arent going to reproduce. Aftermarket speakers arent meant to reproduce those deep lows that you will need to get the full range of frequencies that the songs cover.
Start out with a nice head unit. After that, add your aftermarket speakers and an amp. Then if you feel the need to add some depth to your stereo, you can add a sub, box, and amp.
This all can easily be achieved for around $500-600. You are wanting to achieve good highs, mids, and lows too. Don't skimp out on either, including bass. I'm not saying you need to rattle your SUV, but your low frequencies are important, even in Classical music
HU Amplified Speakers
i agree, but for classical, i really only like to listen to it with a nice full sound. im my opinion, you just can't beat the depth and quality of 3, or 4-way large drivers in the house, even played at low, barely audible volumes. i get more fatigue listening without the depth of a larger driver. it will seem more like resonance, no matter how you tune it. my favorite setup was directed studio 10 with matching components. you are going to find that you loose power and efficiency with aftermarket speakers, but gain sq. silk dome tweeters, poly cones, and rubber/butyl sorrounds always seem to have the best sound to me. i would look at a nice 5-6channel amp to go with whatever you decide, or at least a 4 with option to add a sub amp.
I've been an "SQ guy" ever since I got into car audio at the age of 17. As I try different equipment and expand my horizons I have learned that more power is almost always a good thing. Classical music especially can benefit from powerful amplification on high quality speakers in a good installation. Dynamic range in classical performances can be massive, and when the music builds to its peak you really need to have plenty of power and minimal distortion. SQ can be loud too.
eyalriemer
eyalriemer
Israel
trumpet
just call me KeV
    Oct 9, 2025
just call me KeV
    Oct 9, 2025
