Sold High Output Honda Alternator - 175 Amps
rewintx
HIGH OUTPUT HONDA ALTERNATOR – 175 AMPS
* STILL NEW * NEVER USED! $249
Original retail price of this alternator is more than $700!
Manufactured by Wrangler Northwest Power Products to much higher standards of performance than other brands that simply rewind oem units to make more amps on a test bench and do nothing else to take the extra heat and stress generated by the extra output.
Wrangler hand builds their alternators with many proprietary parts to produce a rugged dependable unit. Here's what Wrangler has on their web site about the difference between their alternators and others.
* Stator Windings that are hand wound, heavy gauge wire, with 200°C slot insulation
* Precision balanced and aligned rotor
* Copper brushes with heavy gauge wire leads
* Over-sized bearings to withstand extreme belt loads
* 50-amp button diodes on aluminum heat sinks to enhance cooling efficiency
* Grade-8 socket head bolts with Nordlock hi-torque lock-washers for mechanical stability
This alternator was originally purchased for 88-91 CRX SI with a round 4-wire plug. Wrangler says it will work on almost any 87 and up Honda or Acura as long as it has a round 4-wire electrical connection. Other vehicles with three wire plugs can also use this alternator with a $30 adapter harness that Wrangler sells directly.
Wrangler says that the pulley and bracket on this alternator will work for 90-02 Accord, 84-02 Civic & 92-01 Prelude. You can always swap out your pulley if you have a different diameter or belt width. Wrangler sells pulleys and brackets for just about everything. Also, any good auto electric shop can supply these parts.
Please contact Wrangler directly at wranglernw.com for specific info about your vehicle. They will ask you for the info form the alternator's ID plate below.
Data from ID Plate: P/N: AN164C, Model: C FR, Amps: 175/160, Volts: 14
rewintx
rewintx
Austin, TX
yischrax
