Hifonics Zeus ZXi60.4+1K 5-channel Amp
i would definately run 1/0 to it.
make sure your big 3 is done in 1/0, make sure you have GOOD grounds in the front and back, and consider getting a beefier batt for under the hood.
Done deal on the 1/0 gauge.. I found a sweet deal on Amazon.
Instead of a stronger battery, do you think a 2.0 Farad capacitor would suffice? I'm not sure why everyone seems to hate caps. Thanks man.
2 farad isn't big enough.
i don't hate caps but there worthless unless your electrical is pretty much up to snuf. This amp isn't enormous so you can probably get away with using one.
if i use a cap i try to use 2 farad's per 1kw class d and 3F for a/b(which your amp is).
with that, you should have at lest a 4F cap.
WesSide
WesSide
Kensington, MD
profundus-sanus
