hifonics vs autotek
I found a hifonics BXI1608D and a Autotek SS1500.1D both for 289.99. Both say they do what i need 1100 rms @ 2 ohms. What would be the better buy?
autotek SS. btw, you can get the ss1900.1 cheaper from H&K in the classifieds section if he still has it for sale, do a search and see
i just sold my XXV Thor and it was rated for 3000wrms. i used the clamp amp meter and DMM and was getting 3447wrms at 13.3v. so i know form experiance that the XXV line from hifonics are doing more that rated. i now wish i never sold that beast. its along the same lines as the crunch GP3000 underrated quite a bit. i would do hifonics not so sure of the brutus amps
Brand New Autotek SS1500.1D 1500W RMS Class D Mono Block Super Sport Amp
1500W 1-Channel D Class Mono Amplifier
1500W RMS x 1-Ch @ 1-Ohm
110W RMS x 1-Ch @ 2-Ohms
550W RMS x 1-Ch @ 4-Ohms
SEPP A/B-Class Super Sport Amplifier Designs
Illuminated, Large New Design Autotek Logo
Super Sport ASPS MOSFET PWM Power Supply For Instant Maxx Current Ouptut
1-Ohm, 2-Ohm, 4-Ohm Capable A/B Class Mono Block Amp
Rugged PRO-FITM MOSFET Audio Outputs
Super Sport Amp Protection with System Diagnostics LEDs That Guard Against: Current / Amperage Overload, Short Circuits, Thermal Overload, DC Offset
Silver Preamp Level RCA Inputs
Daisy Chain Line Outputs
Remote Mountable Bass Control Knob Included
Low-Pass Adjustable: 60Hz to 150Hz
Include Variable Subsonic Filter (15Hz to 55Hz)
Controls Adjustable +12dB Bass EQ @ 45Hz
Input Level Control: 6V
Oversized Speaker Terminals
110 watts @ 2 ohms not so good
Yep, at the amplifiers. I get the same 14.7 volt reading when they cutoff too.
Pull it and test it at the battery post. Simple Power up test to verify if it powers up fine out of protect mode. if it does then Id be checking...
I have a Gemeni VII, Heucules VII, Pluto VII, and a Vulcan VII left out of a massive slew of VII and VIII series. They still work Excellent...
  • Locked
COMPLETED Hifonics Plato III
Yes, they are painted. The cover is very easy to take off and repaint to whatever color of choice to match the install.
p3bumpin
p3bumpin
Brier Hill, NY
audiobaun
    May 19, 2024
    May 19, 2024
