des343
i just got this in a trade...retail on it is around 150-200 it seems..
but im curious it seems to be rated rather low...here are specs
Power Specifications - Subwoofer Channel
RMS Power @ 4 ohms 300 watts x 1 channel
RMS Power @ 2 ohms 375 watts x 1 channel
RMS Power @ 1 ohm 500 watts x 1 channel
Peak Power Output Not Specified
Amplifier Specifications
Amplifier Class AB
Number of Channels 1 - Mono
Total Peak Power Output N/A
Total RMS Power Output 500 watts
Maximum Input Gauge Size N/A
Minimum Impedance Unbridged 1 ohms
Minimum Impedance Bridged N/A
THD at Rated RMS Power 0.01%
Speaker Level Inputs N/A
Preamp Outputs Yes
Built-in Crossover N/A
High-Pass Crossover Frequency N/A
Low-Pass Crossover Frequency 40 - 150 Hz
Subsonic Filter N/A
Signal-to-Noise Ratio 95 dB
Channel Separation N/A
Bass Boost 0 - 18 dB
Bass/Gain Remote Yes
Fan Cooled N/A
Fuse Rating N/A
CEA-2006 Compliant N/A
Amplifier Class AB
Preamp Outputs Yes
Subsonic Filter N/A
Fan Cooled N/A
Fuse Rating N/A
however it has 2 50 amp fuses like the really large ones (first amp with these sorts of fuses for me) but it seems like with a 100 amp fuse rating it should do closer to 1000 rms??
Is this amp any good and can it actually put out much higher than rated?
