hifonics new 5kw and 10kw amps!!!
triplejay
//content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif this year hifonics has two new generation xx amps comin out the goliath and maximus. the goliath does 5000watts at 1ohm //content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif and tha maximus does 10,000watts at 1 ohm //content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif//content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif//content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif
I'm sure Hifonics / Maxxsonics / Crunch is aware of the slander; Perhaps this is an effort to reclaim some credibility.
You'll all eat crow if they juice that much and more;
Are they 2006 compliant?
they cost a buck a watt and they are very similar lookin to u.s. amps' 12,000 watt amps which are massive and very well built. i think they'll b reliable if any of u hifonics flamers could even afford 1
xx stuff always been pretty solid people get the misconception all their amps are the zues or brutus lines. only bad thing i recall on any hifonics hi end is they had some problems with processing but other than that if i recall right the colosus of the 80's was the first 1000 watt amp.
the generation XX amps do their rated power plus some. Dont le tthe brutus amps put a bad taste in your mouth, ever company has a lower line for ppl looking for bang for the buck, its just smart business.
2x 2awg power inputs will not safely provide the amount of current needed for 10000wRMS. I know I wouldn't use 2awg.
Well, thats true and its not true. If someone is running one of these amps, then you must figure they are a competitor, so the amp is not going to be very far from the battery, so dual 2awg may be abley to support the amperage pull needed.
triplejay
triplejay
Atlanta
audiolife
