hifonics bxi1208 blew up :/
deLeo
FL
i was bumpin home and was goin pretty much full tilt not all the way but close.
all of a sudden it cut out and i start smelling burnt plastic, i mute the headunit and pull over i had screw drivers in my truck so the 1st thing i did was took the sub out of the box and checked the coils, coils were perfect. i go over 2 the amp. none of my fuses are blown and the speaker out smells burnt.
how can the speaker out be burnt when the fuse didnt even pop? wtffff cheap *** hifonics shit.
gains were set with multimeter
stinger 0g with inline fuse then a stinger distro fused and the amp is fused. none of them popped.
stinger RCA's
wtf?
mine (1206D 2006 model) blew from vibrations. I had it mounted to the box and didnt realize how much the box was moving in that area... popped my fuse under the hood, changed it out, popped the amp. the fuse on the amp (80amp) never blew. the amp started smoking.
does it still have warranty?
oh hell yeah.. on monday im callin OCS and getting my money back.. going with a sundown //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
im gunna try 2 return my 4channel too
how long have you had em? usually places don't take anything back
Those Brutus amps are great little amps. Nothing wrong with them except the mosfets being mounted at 90 degrees to the PCB. Causes the legs to break off from vibration, can cause the amp to go up in smoke when it happens...
deLeo
deLeo
FL
01 S 10
