hifonics Bxi1206d And Cvr combo ?
if you have no bass output at those settings with it hooked up like this then something is way off, Try testing the subs coils. make sure the amp is actually seeing 2 ohm.you should be all good unless an rca is loose ect.... what is the lpf on the deck set at?
flat and how do i test the subs
how did you buy it direct from maxxsonics? link? i need to see this?what do you mean the lpf on the deck is flat? set it to 100-125 for the sub output, explain "flat" to me.
ok the deck has an flat ,80 ,120,160 and its under hertz or something like that its confuseing i am gonna re set the amp monday when i turn the box around and do some re wireing with my new wire and maxxsonics when i recived it it came in a box that was in a box and the box that the amp was in had a waranty paper and things i paid 150 for it if i knew u had 1 or 1 50 i would have bought it but this was before u had it
ok so no it has no real warranty
Only Onlinecarstereo has a valid webstore for Maxxsonics for future reference, unless you buy direct from an authorized dealer or distributor //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
tristincole07
Beginner Installer
tristincole07
columbia ky 42728
SicAudio
