Hifonics bx1505d
slikrider20
just hooked it up today, some reason you have to turn the volume on the headunit like really high and the gains quite high to get any movement out of the sub, i've chekced everything over and over and over again and i can't figure out the problem. i have my mag d2 wired to 1 ohm parallel.....
I had the hifonics bx1000d before, worked fine for over 2.5 years...it's like i have it wired wrong and it's only seeing like a 4ohm load, or something. but i'm almost positive it's right. Wires out of terminal positive to positive negative to negative into one terminal then other wires coming out of that same terminal to the other side negative to negative positive to positive
I'm now 100% positive it's wired right, wired it exatly like the tutorial on Jlaudio.com. This is ****in weird, the amp doesn't turn on protoect, it comes on right away, you just have to like turn everything up for the sub to even flex
slikrider20
slikrider20
Nebraska
slikrider20
