Hifonics Brutus BXI 1210D wire to 1ohm?
The subwoofer you chose is 500-600 watts RMS and DVC 4-Ohms so yes, you can use the amp and wire the sub parallel at 2-Ohms and it will work just fine.
Of course, because you are at 2-Ohms, you will not be using all 1200 watts which is too much for it any way.
In the future, if you choose to add another subwoofer, this amp will handle the 1-Ohm load you would be applying to it with no problem.
KNIV3S OUT
KNIV3S OUT
Kentucky
KNIV3S OUT
