Hifonics Brutus 2006D
onearmedbastard
Balls deep
So Im looking at amps to power 2 1000W subs. I came across alot of Hifonics stuff, the 2006D to be exact. Im just wondering if Hifonics is good to trust and will truly give me me 2000 watts. I found it for 399.99 at acaraudio. Then I was wondering why it is so cheap compared to the Atomic 2200.1 amp Ive been saving up for (698.95). So some input on the amp would be nice.
the bx2005d is an 05 model whereas the 2006 is 06's. hifonics had a history of making overrated amps in the past and i guess they continue to do so. however, their wasnt any proof the bxi lineup were overrated. (unless someone can show me a link or something...havent kept up with amps for awhile)
hercules is the higher end model and do rated power or even more.
i run bxi2006d and love it. pushes plenty power and much cheaper than a hercules.
From Hifonics tech department.
"The BXi series has a new front-end design which lowers the THD & N.
The Brutus is our most popular selling D-Class amp because it is everything necessary to produce its rated power and is inexpensive. It is not designed for low impedance operation.
The XX Hercules is a competition class amp capable of low impedance burprs, is strappable, and has larger output devices, more output devices, a better regulated power supply, larger transformers and a heavier heat sink per mm.
The Brutus is tested at 14.4 volts and the XXHercules is tested at 13.2 volts. "
onearmedbastard
Balls deep
onearmedbastard
Houston
blimblam
vegang
vegang
