Hifonics 1606d
Ok thanks a lot n2audio I appreciate the help. If I can find an alpine x for cheap enough I may just pick one up. Isnt lanzar a pretty cheap brand?
The Optidrive stuff is good quality -- all the other lines are your typical budget gear.
Type X should work real well. I'd look for the DVC 2, but the dvc 4 would do the trick too.
Since you're wanting to port it...
2.0 gross is going to be on the small side for most 12's but should be adequate. If that is your volume based on external dimensions then you probably only have 1.8 or so internally, after sub/port displacement you'd be in the 1.5 cf area.
For a 10 you'd probably be ok. Somewhere in the 1.5-2.0 range (gross) should be good.
Ok. Will it be pretty loud? It being a 10" I didnt know if the extra watts with the new amp would help. And you say I should get the DVC 2?
Someone also suggested a RD audio Sonance 12". I couldnt find any power handling rating for them though.
1996Silverado
1996Silverado
Arkansas
1996Silverado
