jt15025
Hi,
What is the best way to ground my single multi channel amp? Currently, I have the 4 gauge ground wire from the amp going to the rear of my hatch. I filed off the coating and drilled a hole. Then, using a washer, screwed the terminal ring and washer to the chassis.
Problem is, every several months, the ground connection goes bad and system goes out, as happened yesterday. Driving along, system at moderate level, then......nothing.
Amp was not on at all. Twisted the ground connection a little and the amp turned back on...tunes again.
What would be a better way to create the ground connection?
Thanks,
Viper
Thanks,
Viper
