Here's a challenge for you..
Punk In Drublic
Can someone try to figure out the volume and tuning of this box I just designed?
Two Type Rs will be going in it, specs for the speakers are here:
http://www.crutchfield.com/S-Wdv7igprZFR/cgi-bin/ProdView.asp?g=520&id=features_and_specs&i=500SWR1242
Here's the measurements/pics of the box:
(This is going to be built with .75" mdf)
Outside dimensions: 31.5 W x 15 H x 28.5 L
Thanks a million!
Edit: Just realized some of the numbers in pic 1 are hard to read.
The measurement of the right angle piece of the port (Under the 14 5/8) is 3 1/4"
The port length (From front of box to back port piece) is 25 1/4"
Length from back wall to right angle port piece is 2 1/2"
Everything else is pretty readable. Any questions just ask.
So let me understand this. You're asking us to find out what your design is? You should have a design before you model anything, otherwise, it isn't really a design...
People need to realize that 3D modeling is NOT box designing, it is for visualization purposes only.
Stealing, smealing. That isn't the real issue bass box pro is only as accurate as the person using it. The numbers it gives you are NOT actual numbers, and they are not accurate for anything but sealed boxes. You need to use math to design a box, not a few mouse clicks. Otherwise, you aren't really designing.
lol...right
Punk In Drublic
Punk In Drublic
South Central PA
Trixter
