HELP with RF 700s Amp
Billybob1235
I am getting the Rockford Fosgate 700s amp. I need to know do I need to run 4 g. wire from the battery to the fuse, then 4 g wire from the fuse to a dist. block in the trunk, and then from the dist. block run two 8 g wires to the amp. Because there is 2 power inputs, and 2 ground. Or can i just run 8 g wire from the batery to the fuse, then to the amp?
Please help
Thanx Billybob
I would run 4 awg.... 8awg would work, but I would keep the 4awg incase you upgrade amps or ad an amp to mids/highs.... just cut off the surrounding wire on the 4 awg end so it will fit into the amp... or u can throw it into a dist block and then run an 8awg from that, but thats silly unless your going to hook another amp up soon.
-bryan
the reason it has two 8awg inputs for power and two for ground is for easy installation of a cap, u dont need to use them both.
Billybob1235
Billybob1235
Michigan
Fomskwok
ThxOne
    Aug 15, 2026
TechGuru88
    Aug 10, 2026
