Help with my amp HCCA 2100
I have this amp, that has been sitting in my room for about 8 years and was wondering if anyone knows the specs and the wiring diagrams for it. I dont remember, and was wondering if anyone could help. Also can anyone recommend subs for it, I was thinking 4 15" subs or maybe 2 18" subs. When I had it running it was pushing 4 15" subs. THANKS
i think this is accurate
100watts x 2 at 4ohms
200watts x 2 at 2ohms
400watts x 2 at 1ohm
800watts x 2 at .5ohm
Bridged
200 x 1 4ohms
400 x 1 2ohms
800 x 1 1ohm
Its way under rated and better than anything mainstream made in the last few years.
Itll run .25 ohm as well............That 100 watt amp will push 2 13 w7's.
Bridged
200 x 1 4ohms
400 x 1 2ohms
800 x 1 1ohm
If i understand amps correctly, when bridged, it takes the ohm figure previous to it. Example, if it is 100x2 at 4 ohms, and 200x2 at 2ohms, then at bridged 4, it should be 400, not 200. Otherwise what advantage would there be to bridging? So the figures should be:
bridged:
400x1 at 4ohms
800x1 at 2ohms
1600x1 at 1ohm.
I think all of the other figures should be right, though. Sweet amp!
bridged:
400x1 at 4ohms
800x1 at 2ohms
1600x1 at 1ohm.
Thats what I thought.
The yellow and yellow/black are the +/- for one channel and the orange and orange/black are the other. I'm currently in Iraq or I would pull out the owner's manual for mine and tell you which was which as far as left and right and which ones are used to bridge it. I do know that they were never actually rated to be run at less than 1 ohm stereo and two ohms bridged. I know plenty of people ran them lower, but they weren't rated for it and they probably only got away with it because of impedance rise.
I know that the wires stated are for stereo use , but I was wondering what the wiring was for mono use. //content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gif
revrider1
Hmmm...
revrider1
Down South~3rd Coast~TX
DBBOOM
